V Belt Groove Design - Have I got it right?
  • V Belt Groove Design - Have I got it right?
    Before I put the dimensions in the CNC and potentially ruin a drum, I'd just like to check and make sure I've got this whole V Belt groove dimension right. I think that I've got it mostly right, but I'm unsure that I have the depth correct.
    We're using "B" section belts, which, depending on what site you go to, are either 16.5mm (occasionally 17mm) x 11mm or 21/32'' x 13/32''. You can find these belts here - We're using Bearing Boys as they are on my way home from work and we can just swing by and pick stuff up.
    The depth looks too small to me. Also what angle are the cheeks? When a belt is wrapped around a pulley the inside compresses and widens, changing the angle of the sides slightly - you need to compensate for that on smaller diameter pulleys. Here is a great reference page on pulley design: http://www.roymech.co.uk/Useful_Tabl...Vee_belts.html
      I've read through the RoyMech page a few times, and still don't really understand any of it, especially in regards to what the groove should look like and why.
      The cheeks are 13.5°, O/D of the drum is 200mm.
        All common V belt designs use 40 degree included angle (that is the sum of both side angles). To compensate for the belt deformation pulleys always have a smaller angle; the smaller the pulley, the smaller the angle.
        I had a read through the Machinery's Handbook; for a 200mm diameter pulley, you want a 38 deg. included angle and a depth of at least 14.7mm below the top of the belt.
          I had a read through my ancient copy of American Machinist, got 37.5 deg and 19/32'' depth! I think I've sorted most of it now, and also used a downloaded CAD model of the drive pulley that we're using to make sure.
