"The welds will crack/fracture"
If your welds are done properly then they should be far stronger than any keyed or bolted solution to attach teeth to a disc or ring. Typhoon 2s teeth were welded on and they never once had a failure.
I'm curious to see your idea. No point in every spinner being the same with a large etek or similar motor etc.
