Hi All
looking at purchasing a welding unit in can weld mig,tig and mma but have only used top grade welding packs at work etc. so looking for a little advice on what everybody is using. links below are my two favoured machine both are capable of 4mm + steel thickness and conversion for aluminium mig wire compatible, here's the catch I have never migged aluminium only tig welded but ac tigs are very expensive so mig could be a good solution. any help will be greatly appreciated
http://www.thewelderswarehouse.com/W...-iMig-165.html
http://www.r-techwelding.co.uk/weldi...R-Tech_IMIG180
