How would it be rated against hardox? I have the chance to get it cheap and get it cut to size but wonder if its worth going for if I can get it thick enough and in weight
Stainless and Ali armour
It dose depend on the design of the robot. Mega Mouse uses Aluminium armour very well, with a Hardox or similar blade on the front.
Cherub is made of steel armour not Hardox between 10 -5mm thick, and is so far impenetrable.
Saint is rubber conveyor and 3mm arm400 Steel, wheels 12mm UHMWPE,
Gabriel is 6.2mm armour steel at the front, and 20mm HDPE top and bottom wheels the same!
none are weak as far as armour is concerned, also Beast has no armour to speak off and survives very well.
do you have a picture of your design?
Aluminium is ok if it is thick enough, but Meggamouse didn't like the constant hitting it was getting in Aus from Thor. But then you don't fight Thor 4 times a day and have to let him hit you.
Would like to change but 4mm Hardox will not be sturdy enough, and it would be cheaper to make a new bot.
Make the robot fast and agile and good driving will keep you out of trouble, look at Beast...
Trev
Beast (and Beauty for that matter) are good examples of lightly armoured and well driven
I have to make mine like a tank which is more about my driving than anything
Trev - you said 4mm Hardox will not be sturdy enough. Is the Al much thicker? Interested in the comment.
It's not only thickness that counts. Tough As Nails demonstrates that rather well, 12 years with the same3.2mm Hardox 450 armor/frame.
Flexibility and shape are other factors.
Also, dents and other battlescars ain't a problem, unless those are interfering with the rest of the function.
Better to have dented armor than rattled electronics.
