bosch 750 gearboxs
    Bosch magnet mods anyone
      basic mods are to re-glue the magnets and strengthen the clips that hold them, and weld up the front plate.
        technobots use to do a retaining clip or something to hold the magnets in place for the bosch also i think the iskra 800w motors are still readily available and don't need mods
          couple of last questions,
          ground clearance for a hw - 5/10mm
          125mm blue wheels bearing boys ?
          mounting bosch 750 on face plate it looks like it would benefit from a rear mount as well ?
            Yes - 10 would be top end.
            Yes - used these in Apocalypse.
            Yes - a must to hold the motor together.
              CURRENT GEARBOX IS
              1st stage 12-30 =2.5
              2nd stage 20-40 = 2
              not sure if to run the shafts at different heights form the centre off the plate to make the gearbox more compact
              also might change gear sizes to use multiples of the same gear if possible
                5.1 = 9.6mph
                or easier gearbox 4.1 = 12.1 mph (15/30-15/30) ratio
                • #23
                  Remember to take into consideration the amps being drawn at the different ratios. If you can get away with it I would say 4:1 would be preferred, as your aim is to get opponents to flip the extra torque may not be so needed. Another option could be 5:1 and run a slightly higher voltage?
                  • #24
                    4:1 will be fine, its just when people are gearing for 20mph and wondering why their burning out motors it becomes an issue!
                    • #25
                      still mulling it over o gear ratio don't want something to slow or putting to much load on the motor research is king,
                      wheels rs / bearing boyz or seems like a lot of heavies use robochallange wheels
                      sitting here surrounded by lots of printouts sketching designs on paper (old school) hate google sketchup just confuses me
                      anybody got a legal ish copy of autocad knocking around because that I can use ?
                      • #26
                        Sketchup has an addon for gears. Makes life much easier if you're trying to design your own gearbox.
