Hi, can anyone help me with this lil problem? I have a delbots mk2 interface connected to two 4qd NCCs. The ignition terminal block is wired over, but when I apply power to the 2 NCCs nothing happens, even with a full forward signal and/or adjusting the trimmer- no lights, no movement. Theres definatly power running to the speedos, because when i disconnect and reconnect the battery connecter, i get a spark. One point I think may be causing the problem is, because my input is already powered and doesnt require the BEC on the interface, i have only connected ground and signal. Would this make any difference?
Delbots Help!!
Delbots Help!!
Im fairly sure it would .....
Why not connect up as per instructions?.....or have you got this already?
http://www.delbots.co.uk/data/if2a_29_8_02.pdfhttp://www.delbots.co.uk/data/if2a_29_8_02.pdf
Delbots Help!!
Woody... The input im using isnt actually a reciever, its an RS232 servo controller board (my bot uses an onboard computer) and the board uses its own 12v input.
Cheers Chris, ill give it a go, anyone any idea where i could get a couple of female to female servo leads? hopefully it wont cause any problems with the two power sources :S
