If this is for a h/w then mod2.
How to calculate speed and torque
Mod 2. Module 2. Module is the European system for gears. Module 2 is therefore "Gear, European standard, size 2"
But that's for chainless purposes.
And a housebot or not, 250W per motor, unless you're going to use at least 4, won't give a heavy with any suitable drive capabilities.
Then you won't need a gear-up of 5-1, 3.5-1 or whatever. A 2-1 will do. 40 teeth on the motor, 20 teeth on the wheels.Originally posted by webby View PostI do understand that, but testing has taken place with a 100kg load and it works fine but would have to travel around 3-5mph not the anticipated 10mph
In any case, for a housebot, 250W sounds extreem low power. If you know that the "original housebots" used motors like the Briggs & Stratton Etec with 11 kw of power and gazillions of Nm torque....
