At some point im going to have to replace my hawkers, i am thinking about ni cads, but was wondering what the differance between ni-cad and ni-mh is. As in would it be possible to use 2500ma ni-mh cells in place of the 3000ma ni-cad cells which most people are using? i dont really have the money to just try it, so im wondering if over people have, and what advantages there might be. Ive also seem ni-mhs for around £2.50 per cell, and cost is an issue.
Ni cads
 Ni cads
 Im a bit wirey of useing Nicads now, ive heard they will be made illegal next year
 .... if thats true Black and Decker and the rest of the cordless market are going to be pissed, were only 12 weeks away from next year !
 Luckily its not - The EU currently has a directive which plans to ban phase out the use and sale of NiCad cells in 2008 with a complete ban in 2010. I wouldnt panic just yet about NiCads becoming obselete - and anyway this doesnt allow for the fact that you could still buy them from the US if you wanted to after they are phased out in the EU.
 Mark : in answer to your question, I do not believe that there are any NiMH cells at the moment which can rival the Sanyo N3000CR NiCad cell which people are using to run robots with - it can deliver peaks of almost 200amps and can easily put out 100amps for 10 seconds at a time.
 You could get around the problem by putting additional NiMH packs in parallel, however that would involve buying more cells that you need to give you your capacity, weighing (and costing more) - and thus defeating the point !
 Your best bet would be to look for someone selling some NiCad packs off... have a look in the Archive area of the For Sale section on the forum for people who have been advertising them for sale - its possible they didnt sell them before their advert was taken down !
 Hope thats of some use... and some reassurance to anyone who could have thought NiCads had 12 weeks left on the shelves !
 Ed
 Ni cads
 Note that generally speaking when choosing how many NiCads to use, your choice is based on current delivery ability, NOT capacity. We generally only use 1 to 1.5 Ah out of each pack in a fight (running Boschs off three 24V packs).
 If just running drive motors for a heavyweight, then three packs is about right. If also running an electric weapon that draws a lot of power, then you would probably go for four packs or more.
 You should plan to NEVER run your nicads flat. Once you feel them slowing down, you should immediately stop. Continuing to draw heavy current from them risks reverse charging one or more cells in the pack, which will over time damage them.
 I wouldnt consider using any cell other than the Sanyo N-3000CR. It is what the vast majority of people use.
 Ni cads
 I agree with John and Ed there is alot of scare mungering going around about batteries but certinly by the year 2008 i dont think this set of ni-cds will be up to much.
 I personally would only use the Sanyo N-3000CR or the Sanyo CP-3600. These cells can deliver 80 and 100amps continious respectively.
 Regards
 Ian
 Ni cads
 Cadmium itself is the issue, so depending on its application depends on the timescale. Ed seems to know what hes on about there so thats good enough for me.
 You might want to speak to the stinger team, or the draven team. As far as I am aware, they both use F call NimH, and the big nipper team use C (or is it sub c) NiMH (bet Im wrong and they are NiCad now!!)
 Ni cads
 Kody, NiCads have always been and always will be rechargeable. I dont think anyone would be using NiCads or NiMHs if they were use once and throw away job.
 NiCads are lighter then SLAs, but the SLAs can source a lot more current on peak then a NiCad and they can also take more physical abuse. The Nicads have a much better effeciency rate then SLAs and also are much lighter.
 Ni cads
 james,
 We use 2400mAh Sanyo C cells and yes they are NiCads. NiMH just couldnt provide the current.
 Weve simply got 3x 9.6V & 1x 7.2V RC Racing packs to make up 36V with 3 of these in parrallel (Yes weve changed it again). We did not take theses packs apart all we did is cut the connectors off and joined them together. Each cell is spot welded to each other at 5 points unlike standard packs with just one weld. They are designed for model cars to be fully discharged in 5 minutes.
 We have however burnt the plastic of a few cells when just running one set on the weapon and stalling the motor for a while (with 120A current limit) so you do need to be careful if using these size cells. A test we did a few weeks ago showed a 2V drop with 84A with one 36V pack (better than most Lead acid).
 The 2400mAH cells are far better that the 3000mAH for weight/capacity but have a far lower current rating. We simply used them to get the robot down to weight from Lead Acid as the 3000mAH ones would not provide much weight saving. From memory our cyclon Lead Acid battery weight was 9kg, the 2400mAh (at 28.8V) was 4.5kg and the 3000mAh was 8kg.
 If you can use the 3000mAH ones then those are the ones Id recommend.
