Roboteq ax2550
  • Roboteq ax2550
    Managed too sort the wires out on my roboteq plug after Guildford and have life back in bulldog but currenty on the TX, left is forwards, right is back etc
    Can't figure out which end the issue is at as the leads are all in the same channels and the wires have been soldered too the diagram given in the manual
    Re: Roboteq ax2550
    Switch the channels that the rx leads go into over
      Re: Roboteq ax2550
      May we worth another shot but tried that and didnt work the first time :L
        Re: Roboteq ax2550
        Then switch around the motor connections to one of the channels or try reversing the channels on the transmitter
          Re: Roboteq ax2550
          Ill give that a go
            Re: Roboteq ax2550
            If left is Fwd and right Back, then I'm assuming Up is turn left and Down is turn right?
            Just swap over the Rc leads on the Rx.
              Re: Roboteq ax2550
              I may well have wired it up slightly differently too how it originally was but I shall give those different points a go
                Re: Roboteq ax2550
                Had another go at getting Bulldog working again yesterday
                Took all the servo leads off and cleaned up all the tabs, followed the diagram given in the Roboteq manual and now it works even less
                When the link is in, the valves click as they always do when you power up but the roboteq is completely dead, no power goes too it what so ever, no drive and no flip.
                Any clues?
                  Re: Roboteq ax2550
                  take it out the robot and bench test it
                    Re: Roboteq ax2550
                    Matt- do you have a multimeter?
                    If so, is your roboteq wired up with the red and black mains wires (the thickest ones) going into an Anderson? I guess so...
                    If that's right, unplug it, set the multimeter to dc volts and check the supply voltage to the roboteq as a start. ( check the side of the plug that goes to the rest of the wiring.... Not the half connected to the roboteq.
                    With the link in it should read around 24v. If not your problems easy to solve.
                      Re: Roboteq ax2550
                      Matt, missed this before. Can you explain at all why you say it was shorted out?
                      There is a control board on the Roboteq and a number of voltage regulators in it which can blow if this is done.
                      Andy
