what bore LP ram do you think would be best for a HW?
what bore to go for?
 Re: what bore to go for?
 Repeating again. ADD THIS SITE TOU YOUR FAVORITES.
 Woody included the kitchensink for all who wants to know.
 This is a Feather setup I did make back, in 2004....
 The push lock on the QEV is ment to be connected to the buffertank.
 i used a 100x180mm cylinder in Turbulence running 16bar and it worked petty well...same setup as shown by mario but i used a second regulator to reduce the pressure on the down stroke to 8bar.
 http://www.youtube.com/watch?v=kmFMm-pSeqk
 I'm on Matt's side! I read pretty much every Pneumatics related post on this forum and still I'm pretty clueless as to how it works. That could in part be because I'm not making an Pneumatic bot so not bothering to absorb the info, but things like why in the photo there are 4 pipes going to cylinder only confuse me further.........
