RX Question
Mark,
If you want to drive a 12V solenoid from 24V without it overheating, try just chopping the 24v supply to it at 50% duty cycle. The average voltage will then be 12V and the solenoid will not overheat. This assumes that the solenoid is already rated for continuous 12V operation (check that - some are rated only for a few seconds, or require a chopped/AC supply anyway).
The chopping frequency must be high enough so that the solenoid doesnt chatter on and off of course - a few kilohertz should be OK (less than 20kHz may give you problems with audible screaming of the solenoid - thats up to you!).
You can use a MOSFET or BJT to perform the chopping. If you need a circuit I can draw one, but you may be able to work that out yourself.
Congratulations on getting the range with a BEC - I consider you lucky with that!
					Mark,
