Chainsaw?????
  • Chainsaw?????
    Hey,
    Just wondered if chainsaws are allowed in feathers or heavies? Do they count as spinning weapons?
    Re: Chainsaw?????
    yes they count as spinning weapons, as a rule anything that spins is :P they would be about as much use as a sugar teapot anyway
      Re: Chainsaw?????
      It would look cool though.
        Re: Chainsaw?????
        undoublably :twisted:
          Re: Chainsaw?????
          I think a sugar teapot would be very useful, you get to make the tea and sweeten it all in one step! With the addition of a spoon made of milk making tea would be Childs play!!!
            Re: Chainsaw?????
            you say that but you probably need more than 1 spoon of milk(serving spoons exlcuded) to make a cuppa, think more of a type of ladle, or a cup with milk in it allready
              Re: Chainsaw?????
              i bought a sugar teapot once, i at like a quarter of it then was violently sick. i assume it was for display purposes only
                Re: Chainsaw?????
                Chainsaws are allowed in most cases.
                But keep in mind:
                If using a combustion engined one ,you'll have to start it in the bullpen or arena.
                To restart during the fight you'll need a starter motor.
                Not many event organisers give the permission to run combustion motors in the arena.
                And then practical thinking.
                Try to cut down a tree that moves around, and is trying to hit you.
                Even worse, that moving tree is made from materials a lot more resilient and/or harder than wood.
                  Re: Chainsaw?????
                  It could work against block of wood
                    Re: Chainsaw?????
                    bring it on !!!!
                      Re: Chainsaw?????
                      That's a point; does it count as a spinning weapon? I can see how it could, but then its just a chain with teeth on it, and plenty of robots run chains.
                      Then again, using that logic, I suppose a disc is just a wheel with teeth on it, and plenty of robots have wheels
                      Think I just negated my own question!
                        Re: Chainsaw?????
                        Spinners are defined in the rules:
                        11.2 Limits
                        Rotational weapons exceeding any TWO of the three limits below must be submitted for review and be preapproved
                        by the event organiser.
                        11.2.1 Weight
                        The spinning element is more than 20% of the robots total weight. (This includes any directly coupled
                        motor components rotating on the same axis).
                        11.2.2 Speed
                        The spinning element spins above 500 RPM.
                        11.2.3 Size
                        The spinning element is greater than 24 inches in diameter
                        I think a chainsaw would probably slip under the 20% and 500rpm rule (if set as such)
                          Re: Chainsaw?????
                          so technically, if one was set up accordingly, it would be able to run in something like a robotslive arena? or would the spinner proof arena still be needed?
                            Re: Chainsaw?????
                            You'd have to run it by the Event organiser but if you make sure it complies with the rules to make it an 'un-classified' spinner they shouldn't really refuse.
                              Re: Chainsaw?????
                              Why would a spinning chain be more than 20% of the robot's weight?
