Wheel chair motor
  • Wheel chair motor
    can someone give me some genral specs on wheel chair motors how many amps do they draw rpm tourk horse power
    thanks
    Wheel chair motor
    wheelchair motors are a good drive to start off with. theyre cheap and have a good power output ranging from about 300w to 1hp. not sure on the RPM but it isnt grand. i would assume between 300-500rpm (someone else with more experience may chide in with the actual rpm), and as for tourk i have no idea what that is. but i assume its your spelling.
    (p.s. spell properly please. its way to hard reading your posts)
      Wheel chair motor
      yeah that is my spelling but thanks for the help
        Wheel chair motor
        The torque and speed of wheelchair motors varies quite a lot. The best would be to try and dig up some motors, then check the specs.
          Wheel chair motor
          thanks for the help
            Wheel chair motor
            Take a look at Roger Plants CIMs, with axles and even wheels available.
              Wheel chair motor
              my wheelchair motors have a output of 136 rpm and 180 mm wheels and it gives 4.6 km/h. god or bad ??? they ar rated at 24 volt and 8.2 amp on the plate of the motors, when a test them they only draw 4 amps, strange
                Wheel chair motor
                The stated current draw is with nominal load, so thats not strange at all.
                But that isnt very good for wheelchair motors (some wheelchair motors will peak at well over a horsepower).
                  Wheel chair motor
                  Mats, most wheelchair motors can handle 36 v.
                    Wheel chair motor
                    I know, I tested mine whith 52 volt !!! vroooom :-)))
                      Wheel chair motor
                      Mats, I think that you need testing.
                        Wheel chair motor
                        ok testing BZZZZZZZ testing hv transfo 10 kv 20 mA om my head, AAAAH !!!
                          Wheel chair motor
                          I wonder what this will lead to?
                            Wheel chair motor
                            Probably some psychotheraphy...
