Looking for suggestions on how to remove a screw from the disc on Scar to allow me to get started fixing it up. Its an allan cap screw that is fairly corroded, I have tried the obvious (using an allan key) and even used a hammer on the end of an allan key to try and loosen it but it falls out as the internal shape has been lost. I can get to both side of the screw, if that would help in getting the screw out. Got most of them out, just 2 left to go but the way they are in if one of them is removed the other will be easy.
Cheers guys.
Cheers guys.
