Whats the view regarding flippers and where the hinge is? A front hinge like Firestorm vs a rear hinge like Chaos 2. What is the hinge made of?
Flippers
 Flippers
 The front vs rear hinge argument has been running for ages, so I wont go into that. The hinge on Serranos flipper is a 20mm round bar, mild steel I think. That fits inside a larger steel tube, cut up into sections and welded alternately to the chassis and flipper plate. It runs at 10 bar.
 Flippers
 :-) Not necessarily true, anyway. Usually (because of the wedge shape) most of the weight of a flipper is towards the back of the robot. If you put the hinge of a rear-hinged flipper far enough back, it can gently roll the robot around its rear end - assuming said rear end is the right shape. See Spawn Again, WBC or Thermidor for examples.
 Achieving the same with a front hinge, although it doesnt place any requirements on the shape of the rear of the robot, does mean that the majority of the weight is being flipped, and more of the flipping force gets absorbed by the robot (the rear end, as it hits the ground, will have more inertia because youre moving the centre of gravity higher). So you may need less CO2 to self right (doing this a front flipper is arguably more efficient, in that its shoving more of the robot), but if you dont have a limiting mechanism then the robot will take more of an impact - note the big impact-absorbing tyres on Firestorm, and the way the original Cassius threw a chain when self-righting.
 Not that Ive ever built either type, so this is entirely observational and, in addition to being somewhat incoherent, may be rubbish. :-)
 Fluppet
 Flippers
 I know its slightly off the point here but how do you calculate the mechanical advantage on forward flipping flippers like mute or firestorm. I know how to do it on normal (flip ups i.e. chaos 2 big bro) but not on flip downs.
 Can anybody help
 Regards
 Ian
 Flippers
 Tony: Sorry, what does this help, in Bulldog? Doesnt it just mean that youre more prone to flipping yourself forwards, because your centre of gravity isnt as far behind the pivot point as your opponents is?
 Thats not a criticism, and Im not denying that Bulldog has a highly effective flipper - Im just confused what youre getting at.
 Fluppet
 GORD
GORD
