after having little success buying a hw i now have some motors and gearboxes purchased from here. i have some metal box lengths 1x 1 x 1.2mm. im not sure about welding the box section for strength, should i angle the ends to 45 degrees and just weld them like that? would it be strong enough? im using a gasless mig welder.
also my robot has a wedge on the front will i need to put some sort of small wheels on the front? i want the front to be as low as possible to get under offer robots. it has to wheels at the back, my design will be similar to firestorm.
my other question is about armour/wedge. i cant afford titanium and hardox may be too heavy. are there any other cheap alternatives? i was thinking about 50mm hdpe plastic inside and then maybe put a thin sheet of ali/steel over the outside, but what material would i need for the front wedge.
the robots that spring to mind that worry me are tiberius, kan opener and terrorhurts for causing me damage.
(Message edited by robotnut on November 19, 200
