Would welcome other builders views on using stainless steel as armour, recommend ? or not ?
Stainless steel as armour
Bulldog used 3mm s/s in series 5 its tough but heavy, axes go through easily ,so do spinners
much better off using a version of cast nylon or
Ti mounted on rubber isolators, both very light and very tough especially the nylon option but some nylons need to be kept a little damp,to keep their malleable properties, not usually a problem in this country,
thanks for the input, it was just I had it lying around, the polymer is 1/4 and 1/2 inch plastic, the white chopping board, doesnt shatter like lexan and light.
will probably go the route of the polymer plastic and an outer armour of cold rolled steel mounted on rubber isolators
