2 x Bosch GPA 750
2 x 4QD NCC70 24v
2 x Hydraulic Powerpacks & Rams
2 x Micro Keil 24v 18Ah Batteries
Grab & Lift construction
All Steel, All 100kg Heavy
Right, I said Id do something before the end of the month! My first attempt at a map is now on my profile. It was a very cloudy day when I took the aerial photo of Britain. I have another map which I can overlay the points onto, but its tricky lining it up so everyone is in the right place.
For anyone interested theres also a very initial version of my database up at http://www.srimech.comwww.srimech.com - click on Robots from the front page. Have a play around with it if you want, its not finished so I make no promises. All feedback appreciated.
Aaron: Sorry I didnt include you on the map. Im guessing your postcode is in Australia, is it? I would like to do a world map in the future, but Ill need to do some research on your postcode system first. If you can convert it to a latitude/longitude that would help.
There are sixteen robots on this thread whose owners havent explicitly given me permission to put them in my database - do you think I should just add them anyway?
