Cylinder Ends
  • Cylinder Ends
    At the UK champs Hydra managed to rip out its ram when the flipper came down on the arena side wall.
    Ive taken it out now and was looking at the rod ends and the weight as they are steel.
    Is there any milage in having the reproduced in aluminium to reduce the weight of them. If its been done then have there been any issues on fracturing etc?
    Andy
    Cylinder Ends
    Andy, if you want I can make you such an aluminuim one, will have to be this week as the gaffer is on holiday. Send me an email with all the dimensions and a photo of the broken one.
      Cylinder Ends
      Ed,
      I was actually talking about the other end to the one which broke. I can make the mount from a bit of hardox and an ali bar.
      I was asking about the huge lump of steel on the other end which screws onto the ram. As a weight saving issue.
      As its on the active part of the ram I was just wondering if there was any reason why it would not work in ali or whether it was too fragile etc.
      Andy
        Cylinder Ends
        Provided you use the right type of Aluminium alloy (7075 springs to mind) it should be no problem. But if you do, you should pressure test the ram again (150% of working pressure at least).
          Cylinder Ends
          Ive taken it out now and was looking at the rod ends ..
          ROD ENDS.
          http://www.igus.co.uk/wpck/default.aspx?pagenr=2446&WT.srch=1&WT.mc_id=gadUK3 9&C=GB&L=en&gclid=CIzsstyh05QCFQnllAodK1E_kwhttp://www.igus.co.uk/wpck/default.a...c_id=gadUK39&C =GB&L=en&gclid=CIzsstyh05QCFQnllAodK1E_kw
            Cylinder Ends
            Its difficult to give a definitive answer Andy ...my gut feeling is that it will be fine replacing Hydras rod end with a quality Aluminium item.
              Cylinder Ends
              Thanks Woody, I was thinking the aerospace grade material.
              Appreciate that with the forces involved, whatever you put in there (even steel) it is often a matter of luck because if you hit anything with enough force in the right direction it will break.
              Cheers
              Andy
                Cylinder Ends
                Ah ok Andy, still I can make small things like this no probs.
                  Cylinder Ends
                  make this then ed (unapropriate pic needs to be here)
                    Cylinder Ends
                    Too bad we cant embed pics here anymore. :sad:
