Batteries
  • Batteries
    Would 2, 24v 3700mAh Ni-Mh packs be ok to run 2, 800w Litton motors with 4QD ncc70 speedos??
    Thanks
    Will
    Batteries
    should do, but if your getting into heavys get a pair of hawkers cant go wrong with them
      Batteries
      2 packs is on the low side, I would not reccomend that. We ran 3 x 36V in Hannibal (also Littons 800w).
        Batteries
        it all depends on the drivetrain if its a free drivetrain it should be fine , i know turb used to run 6ah with a free drive train, doesnt draw as much out of the batts so they last longer, also depends if your heavy is going to be a pusher you will need more capactiy because you will constantly drawing alot from them, with a flipper you only need to get under them and flip and then move off again
          Batteries
          it will work if the cells are good. not got much experiance with those.
          Turb used the 3000mah sanyos from battlepack, They did last a fight.. when they were new.. we would of gone for 9amps if we had the weight for it though.
          Having said that though- the nicad packs didnt have a very long life in that machine.. probably because we abused them abit..
            Batteries
            I would use 3 packs. Never been keen on running 2 packs, other thing to remember is that if a pack goes down, you will pretty much destroy the other pack, at least if you use 3, you can finish the fight on the remianing 2 packs (Merlin has done on several occasions).
              Batteries
              We dont plan for a pusher.
              We have a pair of big hawkers and some other 17Ah SLAs but these are quite old and we are not sure of their condition.
              We need to keep the weight as low as possible.
              Would it be better to buy new SLAs (not Hawkers
              due to cost) or invest in some Ni-Mh packs?
              Also we have seen people charge SLAs with car battery chargers is this acceptable?
              We already 2, 14 cell chargers and would have to buy a couple more if we go for Ni-Mh- any suggestions?
                Batteries
                Will test the hawkers, if there all good then you mayaswell use them, wont cost you anything and if the machine is overweight when its finished you can swap them out for somthing lighter. We did that with the original turb when it turned out to be 14kg over weight at its first event lol.
                  Batteries
                  Pick a car battery charger that will charge leisure batteries or SLAs.
                  Ive been using this model for years.
                  http://cgi.ebay.co.uk/GUNSON-12-VOLT-AUTOMATIC-BATTERY-CHARGER-model-4106_W0QQitemZ200224558720QQcmdZViewItem?_trksid=p 3286.m20.l1116http://cgi.ebay.co.uk/GUNSON-12-VOLT...el-4106_W0QQit emZ200224558720QQcmdZViewItem?_trksid=p3286.m20.l1 116
                  (Message edited by woody on July 06, 200
                    Batteries
                    I have a question, I have just switched over from 24v 3600mah Nicds to 2 Hawker/Odyssey PC535 24v 13AH batteries, due to cost $96 US instead of $172. But at the expense of weight, my question is do any of you guys running these batteries charge between fights or is there enough juice to run say two fights ? The Defyer is HW two wheel running on two mags.
                    Martin
                      Batteries
                      Martin, you should always aim to charge hawkers between each battle. The deeper they are discharged, the shorter they live.
                        Batteries
                        Thanks that what I thought but just wanted to check
                          Batteries
                          Would this be a suitable charger just to check these old SLAs Will and I have aquired !
                          http://www.argos.co.uk/static/Product/partNumber/7402137/c_1/2%7Ccategory_root%7CGarden%2C+DIY+and+leisure%7C95 54618/c_2/3%7Ccat_9554618%7CCar+equipment%7C9554675/c_3/4%7Ccat_9554675%7CCar+battery+chargers%7C9554688.h tm?Price+Cut=1http://www.argos.co.uk/static/Produc...ategory_root%7 CGarden%2C+DIY+and+leisure%7C9554618/c_2/3%7Ccat_9554618%7CCar+equipment%7C95546 75/c_3/4%7Ccat_9554675%7CCar+battery+chargers%7C9554688.h tm?Price+Cut=1
                            Batteries
                            Ian, That would do very well.
                              Batteries
                              Thanks Leo...as the spec says Suitable for use with car batteries - 6 volts/12 volts/ sealed/ lead acid/ gel cell batteries between 20-120Ah - Charging rates 5.3 amps RMS would it be advisable to charge 17ah in parallel ? Read somewhere optimum C is 25% of capacity for SLAs
                              Our current batteries are old but we might buy some new SLAs so want to make sure we use the chargers properly from the start. At £20 each cant be a bad buy if there upto the job !
