Water Cutting
  • Water Cutting
    Hi,
    I need to get a few bits watercut. Can anybody recommend any companies that can do this for a good price? Closer to surrey the better as i will have to take the material over to get cut!
    Thanks
    Suren
    Water Cutting
    Ive used ML fabcuts (in Higham, Kent) for a few things for work and theyve always been way cheaper than anywhere else and often they can supply the material. Cutting+material from them has come out cheaper than just material from other places.
    Theyre also fairly quick and reliable.
    Mark
      Water Cutting
      is there anywhere in bristol?
        Water Cutting
        close enough?
        http://www.jetshape.co.uk/index.htmlhttp://www.jetshape.co.uk/index.html
          Water Cutting
          where is it?
            Water Cutting
            Visit us at: Jetshape Ltd, Blackcomb Works, Mendip Business Park, Rooksbridge, Somerset BS26 2UG
            on contact page
            so i guess its there
              Water Cutting
              http://maps.google.co.uk/maps?hl=en&q=BS26+2UG+&um=1&ie=UTF-8&sa=X&oi=geocode_result&resnum=1&ct=imagehttp://maps.google.co.uk/maps?hl=en&...&oi=geocode_re sult&resnum=1&ct=image
                Water Cutting
                can get plasma cutting at work if your local to Walsall,
                  Water Cutting
                  Mark, thanks for the advise. i will speak to ML Fabcuts to get a quote.
                  Tony, Wasall is MILES away!
                    Water Cutting
                    well its there if you need it
                    Der Boyz
                      Water Cutting
                      what does ne1 reccomend the easiest way is to cut
                      6082t6 13-15mm alluminium plate ??
                      Im getting problems locally with poeple wanting to machine it,
                      They must all just be to lazy in east anglia !
                        Water Cutting
                        I may be able to help Terry i have just had some aluminium water jet cut looks great if you could drop me an e-mail with details???
                          Water Cutting
                          We have band sawed and jig sawed t6 10-12mm thick
                          on many occasions just take your time cut slowly and lube with paraffin
                          Der Boyz
                            Water Cutting
                            Cheers, I will give the jigsaw and paraffin a try
                            1st, ive also got e few 60mm holes in the plate to drill but suppose if a jigsaw is ok then maybe a high spec carbide holecutter might go through it ?
                            As soon as I have auto cad pics I can send some to you alex, what was the average cost per meter of cutting ?
                              Water Cutting
                              I believe one of the Aussies used a carbide holecutter to drill two holes through 30mm thick Bisalloy; says it took an hour per hole and lots of lube but it got the job done.
                              Cant guarantee it but it should be fine for the ali as long as the workpiece and tool are kept cool
