Upgrades
  • Upgrades
    the new watty speedo has arrived, what can i say very nice. looking to change the batteries in the robot as they are big,heavy and old. it runs on 24v (used to run on 2 4qds) and has 4x Gastron 12v 18ah?, i think their from a golfbuggy or something. all im running are 2 bosch 750w motors and the hydralic weapon, can anyone recommend something that will give me as good performance, save some weight, (on a budget with this), and need a affordable charger to suit also.
    (Message edited by ady on August 27, 2007)
    Upgrades
    either NiCads (will prob cost abot £500 for a setup with chargers), or look at the 13Ah Hawkers, slightly smaller/lighter than the normal 16Ahs and can supply loads of current and will be much better than waht you currently have.
      Upgrades
      nicads? could i use my pro peak constellation chargers with them? as i have 2 of these for the featherweights.
        Upgrades
          Upgrades
          theres an echo
            Upgrades
            Yes Ady Yes Ady
              Upgrades
              , ok sounds like nicads are the way to go, do i need to have these packs custom made up? or are they something i can get off the shelf?
                Upgrades
                technobots do them
                http://www.technobots.co.uk/acatalog/Online_Catalogue_Bot_Pack__High_Performance_19.htm lhttp://www.technobots.co.uk/acatalog...ormance_19.htm l
                  Upgrades
                  Its 3 packs of ni-cads youll want Ady.
                  Nearly £400 .....
                    Upgrades
                    cheers woody
                      Upgrades
                      BTW ...Ady,
                      You could consider increasing your Pack voltage to 30v ... your Chargers ...as I recall will do 30v packs... that is assuming the Wooty will also handle the voltage.
                      Just a thought
                        Upgrades
                        absolute max on a watty is 32volts, so should be ok.
                          Upgrades
                          i dont know bout that, i have 12ah of 28.8v packs and when fully charged are putting out over 37v for 5mins
                            Upgrades
                            kenny, im just going on instructions i recieved with mine last week from ian watts and to quote absolute maximum voltage 32 volts, you will damage your wotty above this voltage and it also says under how to kill your wotty, number 2 (connect more than 32 volts to it),
                            (Message edited by ady on August 29, 2007)
                              Upgrades
                              Kenny is pointing out that the 30v Nicad packs .....when freshly charged .... will have MORE than 30v in them.
                              Therefore your Wotty may go POP!
                              Check with Ian to be safe.
