hi people, have acquired 2m sq of 6mm polycarb, is this thick enough for heavyweight armour? or should i double it up to make 12mm. also any tips on cutting and drilling this stuff as i have never used it b4. thanks
6MM POLYCARB
 6MM POLYCARB
 12mm at least in my opinion.
 A coarse toothed circular saw or jigsaw on slow should do the job...... go too fast and the stuff melts.
 http://www.sheffieldplastics.com/web_docs/PDS062.pdfhttp://www.sheffieldplastics.com/web_docs/PDS062.pdf
 (Message edited by woody on April 30, 2007)
 6MM POLYCARB
 Toxic uses 10mm in most places which normally is ok, there was and still is some 6mm but this gets pushed in and cuts to easily so I have doubled up 2 x 6mm which is better, but ive found 1 x 10mm is better (12 better still !)
 I use a jigsaw to cut it its easy and even half blunt drill bits drill through it ok.
