Astroflight Cobalt 40s
which assuming no friction anywhere in the system and no voltage drop under load gives 3910rpm at 17.2v
meaning for the calculation to still work, loosing no voltage at all (defying physics again) the gearbox, air resistance, and assuming the disk has 1 hour to spin up, means you cannot be less than 80% efficient.
still doesnt add up, but glad your batts are so good JC, at that rate you batts would have 43v instead of the rated 36v
nice
nice
