TBH, anything from the OrangeRx range is good (I use a Tx6i + R618XL) but you do need to check that the receiver you are using transmits on the protocol that the transmitter uses (So DSMX to DSMX, DSM2 to DSM2 for example). This isn't normally a issue as both the one I use and the one DoubleTrouble noted above support both.
Certain models of receiver, like the FlySky series I think, have proprietary protocols which means you can only use their model of receiver with their transmitter. Same for the Devo 7E but those can be flashed with a firmware update to support the DSM protocols I believe.
