Wyvern – New featherweight spinner build thread
So I thought I would start a thread for this as I think my design is sufficiently progressed. I still have some significant design hurdles to get over, but more of that in a bit.
I am building a spinner which looks vaguely like this! (some bits are incomplete around the weapon)
So it is a fairly “classical†bar spinner construction. Spinning bar will be 40cm long hardox, 10mm thick. MOI of 0.017kgm^2. I have put spurs on the end to enable some penetration as opposed to blunt impact. Will be driven by a 100KV brushless outrunner.
The drivetrain will be two scavenged 12v drill gear motors directly coupled to nylon wheels. I am not prioritising too much speed here, as I want it to be controllable. I have seen enough footage of spinners wrecking themselves on the area wall rather than their opponents! I have demonstrated this drive method on a chopping board testbed so I am happy it works.
The chassis and armour will probably be HDPE. 15mm thick base (to take the severe shocks the spinner will inevitably generate), 10mm thick lid. The rear panel will be angled HDPE, which I am confident will deflect shots fairly well so I am happy with HDPE. The side panels are naturally more vulnerable, so if I have spare mass I will upgrade these to aluminium or titanium if I am feeling fancy, otherwise 10mm HDPE it is.
Lid will be 10mm HDPE. Part of it is easily removable for basic maintenance, also with a hole for the removable link. The wider part can still be removed but will obviously involve removing the spinner.
The details:
Weapon drivetrain
So I used the spinner spreadsheet and get the following:
So it reaches a respectable level of energy in a short time assuming 1:1 gear ratio. The numbers seem reasonable here, but please flag me up if I am missing anything glaring! Checking the FRA rules, the weapon mass just fits within the FRA spec limits, with the length compliant also. RPM is higher than the 500 mentioned in rule 11.2, but one exception is deemed valid.
This is my intended motor
https://hobbyking.com/en_us/9235-100...tor-motor.html
I am thinking along the lines of the following for the ESC
https://www.ebay.co.uk/itm/YPG-HV-12...-/272564034278
I will likely run at 12s with two of the following
https://hobbyking.com/en_us/turnigy-...450l-heli.html
The burst C-rating is pretty high, so two in series should hopefully be ok. Again am very interested to hear if other people’s experience confirms or defies this!
The main remaining technical challenges concern the weapon drivetrain.
I am looking to use a belt drive, with a lawnmower style V belt of 10*6mm section. This belt will drive a very chunky, stainless steel coupling pulley with the weapon blade. The blade sandwiches between two halves of this coupling, held together by two M8 bolts. Flanged bushings run between this coupling and a stationary 15mm SS shaft.
The first bit I am struggling with is to find a decent source for locking bushings to couple the shaft to the main housing. This is partly a struggle because I have no idea what the consensus name is for one of these!
https://uk.rs-online.com/web/p/locking-bushes/4776666/
What solutions have people used to couple shafts to their housings? Would ideally like to find something off the shelf than build my own, makes repairs far simpler!
The second challenge I am struggling with at the moment concerns tensioning the belt. I Intend to place an idler pulley somewhere near the front bulkhead (either inside or outside the belt), with some means to adjust it for belt tension. I am struggling to find a suitable tensioner assembly to put in though. Does anyone know of any standard components for tensioning? If I really need to I can design my own, but it would be a hassle. Probably some kind of serpentine moved by a ballscrew.
I have a decent amount of space near to the weapon motor so I am confident this is a solvable problem!
More to come on this as I solve these finicky details. Once I have a way forward I will start ordering bits.
5upercrab
The details:
Weapon drivetrain
5upercrab
