I'm going to setup a demo drive unit using brushless as a learning excercise. The plan is to use some bits for a test chosen I hope so they can be expanded on for different configurations as the experiments continue.
The aim therefore is to use a 2836 1000kv prop drive V2 into a banebots p60 at 16:1 with a 5" wheel. I'm going to drive this with a Hobbyking F-80 on 4s. I'm picking that as it has the range to do 6s if I want to play with bigger out runners in the future.
ive got got lots of Colson 5"x2" so probably need the banebots 3" shaft but will do that once things seem to work but will start on other wheels for now.
I've seen robots like crippling depression run nice on these esc's and all the bits seem to be in stock and easily available in the future. Comments and practical experience gladly appreciated.
Ive got got lots of existing brushed configs, so this is a foray into brushless as a test.
