Not in a miserable way, but in terms of other weight classes becoming spinners and bricks. I want to build a lifter but doesn't really seem much point if spinners are becoming wide spread at the live events and we're not allowed to snag the blades and bind them up.
Is it worth building an active weapon anymore?
I realise I'm adding this reply as someone who has just posted a build diary of what amounts to a ram bot with no active weapon, but I still think active weapons are worth doing for a few reasons. For one, I don't plan on keeping the bot without an active weapon forever, but its a 'cheap' test platform to see that works against spinners and what doesn't particularly when you have never fought them before. Likewise, not every fight or event is going to have spinners in it and a load of ram bots / wedges pushing each other is only going to be slightly less dull than if every fight was spinner vs wedge.
I think there are probably lots of designs that could beat spinners as evidenced across all the weight categories. Wasn't it Rory's lifter than won the gladiator battle at the last FW championships for example? Variety is the spice of life and all that.
Yet a flipper is a Featherweight champ and Heavyweight champ form the same team.Originally posted by daveimi View PostNot in a miserable way, but in terms of other weight classes becoming spinners and bricks.
there is only three arenas in the UK which can contant spinners.
Robot Wars (only class one arena IIRC)
Extreme Robots has a Class two arena IIRC which the spinners a limited in power
Robochallenge class 2F (featherweights only) which Neon (Ellis's featherweight) couldn't run a full power due to having similer enengy in its bar to a "low yeild heavyweight" spinner
so yeah there is plenty of reason to build non spinner active weapons, one being that you can go to way more events.
*cough*Originally posted by daveimi View PostNot in a miserable way, but in terms of other weight classes becoming spinners and bricks. I want to build a lifter but doesn't really seem much point if spinners are becoming wide spread at the live events and we're not allowed to snag the blades and bind them up.
electric lifters 4 lyf
