Im sure ive seen this done. Can anyone tell me how
Tamiya wheels onto drills.
 Not what we do. Originaly I used a M10 D3 nut (D3 stands for 3 times the thread diameter in length), what has an Hex 17 size. Some lathe work, making them up to the right length and drilling/reaming the center to 12mm, using loctite 368 glue and a few setscrews to lock that adaptor to the Original shaft.
 The 3/8unf nut and left hand M5 bolt are used to lock the RC wheel on the adaptor.
 And we use soft 1/8 scale wheels. Those survive fine unless a spinner gets to them. And even then the damage is acceptable.
 It's rare for us to replace the soft, light wheels after 1 fight. Even on the exposed versions.
