That is a lot of linkages but even so, I can't see why it would burn out a motor unless it was out of sync...?
Project Squirrel
So I was a bit of a pillock in describing the motor burnout, and I found the proper failure point. The first linkage from the motor didn't have any relief (room for the bolt to move back and forth so the motor can make it's full rotation) so to speak, so the motor pressed against an immovable object. Whiiiich in turn lead to a busted drill motor...
But, I bought some LED and a 24v scooter motor that'll be ran at 18v, so major thanks to you guys for the links and recommendations.
Well this may be a little annoying, ahaha.
So I took a proper look at the new motor I got, and I figured I could try and get the timing belt... gear, is it? either way, I thought I could get that little piece off and then stick some hdpe to it so I can retry the mechanism and move from there... not so easy, as I have no idea on how I could get it off. It's got little tabs that hold it to the keyed axle of the motor and it refuses to move... any advice on how to get it off there without breaking it all? Or would it be better to bite the bullet and go for a belt driven axe?
From the ebay link, it has a circlip on the end of the shaft (The little black ring).
You just need to push that bit off with a screwdriver or something and the pulley will slide off the D-shaft.
So thanks to you guys, I figured out how to get the circlip off, or e-ring, or whatever it's called haha. But I'm still stumped on how to remove the pulley itself off? Would a pulley remover be a decent shout? And if so, what kind would you recommend?
So I saw some advice on the internet and I'm not sure how well it works... basically, you take two flathead screwdrivers, put them either side of the underneath of the pulley and slowly press down on the handles to push them up and eventually get the pulley up and off... good idea or no?
I would only do this if there was something supporting the motor, you don't want the screwdrivers flying off and doing you any harm. I would look for a ball joint puller - normally for windscreen wipers but I reckon a small one might do the job here.
