All three still work, 2 for drive (running two motors each) the third for the Linear Actuator. Held in place by a zip tie and a bit of foam padding between them and the HDPE chassis. After the weekend of 8 fights they we're working loose. But suppose I should also point out, I wasn't facing any spinners or massive flippers. Manchester was more of a pushing and shoving battle. For testing and playing they will be fine. The feather rumbles at the live events, again should be fine. But serious full on combat like the UK championships.. Guess I'll find out once they publish a date!!
I use a 4s lipo (15v) and 4 cheap cordless drill motors. The rated 60amp on the box I wouldn't believe, I've read lots of stories of Chinese Amps compared to normal amps. But doubt the motor would draw anywhere near that anyway. (suppose I should really change my fuse for a smaller one, just incase. Currently have a 100amp installed. lol. That's another way to ensure its a tad more protected, use a fuse whos amps are lower than the esc's rated MAX.....
The only problems I had was my driving into the pit, (again not helped by the bot turning during acceleration and braking occasionally), The bottom hinge of my actuator bending and sticking out the bottom of the chassis lifting my wheels off the ground and a receiver plug falling out.
Asking for advise, you're in the best place, I was where you are 6-9 months ago. But there comes a stage you just need to take the plunge, buy and test it. I'm doing the same with my heavy at the moment. Constantly online checking specs of components and looking inside everyone's bot, to see what they do, what works. I need to place that damn order and just connect everything up, but worried I'm wasting 100's of pounds. Why starting with feathers is much more wallet friendly, mistakes only cost 10's of pounds......
