Spinner Weapon Motor Discussion
John, Our first spinner used the same pancake motors. It had a 2:1 ratio on a 600mm dia disc with the disc weighting only 500 gramms. These motors are very slow compared to an EV or Astro so a big gear ratio would make it run slower, It used a large O-ring for the belt from a car asseccory shop on 2 very deep pullies. We did have one problem with the motor as the shaft is only pressed into the disc armature and it started spinning after only a few test hits. A couple of grub screws fixed this easy enough. On testing we were actually using 240W of power once the disc got to full speed and even more spinning up, so after a fight it was red hot but we never burnt it out.
 Easy way for me is to use a PicAXE 08M or my IBC
