New Pulsar looks so good...
the design is now more or less inverted to what Ellis did.
Disc in the middle, and an (aluminium?) pulley on each side of it, with a small distance (maybe just a washer, planning with 2mm here) between so the motor pulley will have some clearance to the disc, too.
Now i'd put holes into the spokes of the disc, and put bolts from one pulley through the spokes of the disc into the other pulley.
One of the reasons i want to go with four spokes, so i can use at least four (or maybe, depending on pulley size eight) bolts to hold everything together. Not the ten bolts Ellis used, but i'd hope enough. maybe i should put a smaller inner ring into that design of the disc, so i could bolt through that instead of just the spokes.
Drilling recess points won't be that big of a problem for me, i'm a dental technician and used to work with small, but really hard stuff precisely. those are seldom round, but i think that should be achievable for me.
But why is it that grub screws suck?
hard to repair/get out once damaged? not strong/reliable enough?
One more question:
Why silver steel for the shaft? Does it have any special properties, or is it just the cheapest stuff you could use without problem?
About mounting the motor:
there are 4 screws M4 to hold the motor, distance from middle of one hole to the middle of the opposite hole 25mm.
shaft is 6mm in the middle of those, but having this ringy thing at it right where it comes out of the motor.
you said i could just not have the circlip on the new shaft, but wouldn't the endbell come off then? how would that hold? Just by the pulley not getting pulled through the bearing? That feels so wrong...
One more question:
