Right. Trying to knock up my belt drive with roughly a 1.5:1 ratio. There are plenty on Amazon but most only have 1 in stock or take 2 months to arrive and I obviously need 1 for each side, plus perhaps a spare or two.
I need 6mm shaft for the smaller pulley, 8mm for the larger. Size is an issue because my robot is pretty low to the ground. Does anyone know a great source for items like this? https://www.amazon.co.uk/dp/B00TGQJW...I27SBVAX4NWH9O
Also, I should probably know this but how do you join the belts together? glue?
Cheers,
Steve
Cheers,
Steve
