Ok so.... scissor jacks...
changing a wheel on my van the other day, put the scissor jack under my van, took out my impact wrench with 19mm socket to drive it instead of using the crappy manual way.
This incredibly simple 18v setup lifted my van in seconds with no problem at all.
so it got me thinking... how could I use this to run a crushing weapon.
a simple leaver setup at 1:2 would give you 20cm of travel on the crushing arm at twice the force applied by the jack.
the full travel you get is roughly 40cm and it takes my drill about 4 seconds to do that.
but it's a hell of a ballache to make this work in a fixed location e.g., inside a bot.
then i saw this...
https://www.ebay.co.uk/itm/391560570218
is this the answer or at least on the way to an answer to a 4 tonne tip pressure electric crusher??
i thought I'd post here instead of just going out on a whim and trying it.
I also wish to ask about another method.... as seen here: http://www.fightingrobots.co.uk/thre...ghlight=Lifter
his method for gripping the bot is interesting. I would want to change it slightly to run a piercing weapon but Would I be able to produce much pushing power if I used my impact 18v wrench to drive it?? (Compared to the jack) It has a rpm of 1600 and torque of 440. Also I think having the impact effect would help it pierce into stuff.
so thoughts or advice anyone?
then i saw this...
