Motor advice
  • Motor advice
    Hi all,
    Would the following be any good for use in a featherweight?
    https://www.ebay.co.uk/itm/391532256037
    a bit on the small side for featherweights as far as I can tell from the info they give, with that amount of reduction it would probably be useful for a beetleweight lifter or something along those lines
      Not strong enough.
        Ok thanks. What's the best starting point for featherweight motors?
          the motors and gearboxes from cordless drills are a good starting point and fairly cheap too
            Cordless drills are the main source of drives in featherweights.
              Hi
              Check out WWW.ranglebox.com
              We use his motors and gearboxes.
              Ian
                So does Team RCC.
                  Thanks both. Currently low on Saturn-16s and the new Neptune-28s do exist but just not had the time to take the photos and write the product page. Also currently negotiating a sizable ESC import as there is stacking demand. Just the nature of small business - such a balancing act of time and funds!
