Banebots wheels on Saturn-16 output shaft?
  • Banebots wheels on Saturn-16 output shaft?
    Hi, I am thinking about buying some of the motor/gearbox combos from Ranglebox:
    http://ranglebox.com/product/775-18v-motor/
    http://ranglebox.com/product/saturn-...etary-gearbox/
    and was wondering if anyone could tell me of a way to attach 2 7/8" Banebots wheels to them?
    http://www.robotshop.com/en/rb-ban-94-orange-wheel.html
    Thanks in advance,
    Ben
    By using the half inch bore hex hub and some 0.25" shim material wrapped around the shaft. Worked a treat on boner for a similar problem.
      That will be difficult - the wheels have a 1/2" hex bore and the motors have a 12mm shaft; you will probably need a custom hub and to enlarge the bore in the wheel, which is more trouble than it's worth. Don't bother though; the orange wheels are garbage and will wear out after a couple of matches.
        any replacement suggestions that are easier to fit?
          To be honest, I don't know of any off the shelf hubs with a 12mm bore and a 3mm keyway - perhaps some enterprising lad can capture the local market .
            I just fit a 17mm hex on the shaft and use that for RC wheels with an hex 17 uptake.
            But I made hubs to fit on the Saturns. Pity it isn't a 4mm keyway, as that is industrial standard.
              Whoops! Didn't realise it was the smaller wheel size.
                The smaller T40 wheels only have hub bores up to 6mm - the larger T81 wheels would be a better choice if you still want to go that way. It might be possible to buy T81 hubs with a 3/8" bore and drill them out to 12mm and then broach a new keyway.
