So, looks like I'm in need of a good brush up on my physics!
I just need a proof of concept for now which will need to evolve...so the issue is this :
A double acting cylinder will produce less force on the retract side due to the area reduced from the piston face by the piston rod, right? - the larger the rod diameter the less will the retract force will be.
Now I need to increase the force on the retract side without increasing the pressure, but at the same time I can't use a small dia rod as that might buckle. If I had to machine the rod and reduce the rod diameter at the piston face only, would that result in an increased retraction force?
Any ideas?
Any ideas?
