Chassis Materials
    So HDPE is lighter than I expected, very good thickness to weight ratio. Whats the best way to go about fixing HDPE? My design involves angled bits for those nasty spinners - no 90 degree angles lol. So brackets? Tapping it for the shape I need would be a pain I think, but if it would be better tapped I'll put some time into it (Maybe a combo of tapping a few bolts for the bulkheads into the base along with brackets and brackets for the outer armour.)
    That is also a great idea maddox, that base must be bombproof! And cheers higgeh I just was hoping to get an idea of how tried and tested HDPE as a base is for a feather thats all.
      I fix HDPE with about any means possible. Ranging from wood screws to bending and welding.
      From Ranglebox nutstrips to selfmade barrelnuts. Even Titanium brackets with rivnuts and bolts.
        I've been going M6 barrel nuts and tee nuts all the way with my design. Right pain in the arse to get the two right-angled holes aligned properly though. XD I didn't know you could weld HDPE? What do you melt it with?
          HDPE is a thermoplastic material, and it's commonly welded with a hot air gun and a specialised nozzle to feed the filler material.
          I use the same hot air gun (not the cheap paintstripper stuff, but a fully adjustable Leinster) to bend HDPE.
            I thought about using thick and coarse woodscrews, stronger than you'd think I imagine? Interesting about the welding, does the heat not make it warp though?
              If you do it right, the welding doesn't distort the HDPE.
              And woodscrew don't cut the cheese. T and barrelnuts are the better options.
                I might test my plastic welding skills on some offcuts lol
                • #23
                  With the proper heat gun, welding is really easy - I figured it out in about 5 minutes after watching a couple of videos. For thick and structural parts of a frame, I would still use barrel nuts; they are likely to be stronger and allow you to replace damaged sections.
                  • #24
                    Nick, you figured out TIG welding , and TIG welding Ti after watching a few video's. It seems you're a natural.
                    But yes, HDPE welds tend to be more brittle than the base material and benefit a lot from some metal reinforcements.
                    • #25
                      Hardly a natural, I still suck at welding steel for some reason. Another reason for getting set up to weld HDPE is that the hot air gun can also be used for heat forming - 5mm HDPE bends very easily and 10mm bends with a bit of patience.
                      • #26
                        Hi Guys,
                        I've been thinking about chassis material recently too..... I'm considering using a 3.5mm Mild Steel Angle welded to make a frame chassis then bolting HDPE (6, 8 or 10mm depending on weight) as easily replaceable armour panels.
                        Does this seem like a daft idea? (I'm thinking it might be as I don't see anyone else suggesting this method )
                        Cheers,
                        Alex
                        • #27
                          Im sure a much more experienced head will help you out but that sounds like a fine idea to me, I take it that you are building a feather?
                          • #28
                            A basic steel angle "wireframe" with bolted on HDPE sheets. Works.
                            But I would suggest using other material than DIY grade steel or even worse, cheese grade ali.
                            I know at least 1 feather that uses hardox strips to connect the sheets.
                            • #29
                              Thanks for the info guys..... I think I'll stick with the Steel Angle chassis with HDPE Pannels bolted to it, but maybe the Mild Steel Angle I picked up cheap from my local B&Q that was shutting down isn't the best...
                              Cheers,
                              Alex
