You wouldn't want to gear them down more, they're already on the slow end of drive.
If we take a 2wd bot and a 4wd bot as an example (Most the principles of a 4wd bot apply to tracks). When a 2wd bot turns the wheels just turn and follow the arc of the turn. When a 4wd bot turns the wheels slip sideways as they aren't lined up with the arc, this produces a high turning load as the motors now no longer have to turn the robot but also slide the wheels across the floor to some extent.
So while 2 drill motors will happily move and turn a 2wd bot a 4wd bot is a much bigger challenge and is likely to burn them out. Tracks add to this by having the turning load of 4wd with the extra tension and friction of tracks leading to a very quick death to motors. This is why most drill motored robots that are 4wd use 4 motors as they need more power.
You can do 2 motors for one side off of one esc, a TZ85 will be perfectly happy with 2 drill motors.
One thing with tracks, it's fine if you want to go that route but be warned they offer a lot of extra challenge and unreliability for no considerable gain other than looking cool. :P
 For a first build sticking to tried and tested stuff is usually a big help till you find your feet. It sounds crazy but in a way there aren't many positives for tracks other than looking cool and being a bit different. It's added complication and they're really hard to get right. A lot of the basics of robot building use tried and tested methods, and the advice is usually to stick to the tried and tested methods to get the basics and use that as a base to build upon.
						 Either way, hopefully it'll be an interesting and educational experiment.
