Hi everyone. I am planning to build a featherweight pneumatic flipper robot and I got some question.
I plan it go in 1 Mpa(145 psi) in the 80mm bore 80mm stroke ram, do you think it work?
I can't find any ram can operate upper 1 Mpa, I think a self made ram is too dangerous for a people who first time build this kind of robot.
What regulator you usually use? I can't find a regulator can input 30 Mpa and output 1 Mpa
I do not know why using a motor from a drill, I can buy a motor with gearbox having the same performance. Is the gearbox in the drill more durable?
I think a flipper robot may be too complicated as a first robot, what kind of robot do you suggest as a first robot?
I would like to attend the RoboChallenge 2016 if the robot can complete.
