Hi,
I'm curently planning what's next for me and robotics, one possible option is a full combat feather weight. I'm trying to figure out what sort of design I wouid go with so I can think about costings and where/when/how I would build it.
What I was wondering was what material people recomended as a non-structural lid/baseplate? I wouldn't want anything mega expensive but want something decent, hardox would be too heavy. Each plate would be roughly 250x200mm, well supported around the edges but not really anything in the middle although I guess I could have say and aluminium column in the centre between the 2 plates but this could well do more harm than good?
Some options I was thinking about:
-Titanium: not sure what thickness is necessary but would imagine 1-2mm but fear this would be cost prohibitive
-3-5mm Glass Fibre sheet: I use this material in antweighs and it is very easy to work and machine and easy to get off eBay but not sure how it would hold up against featherweight axes and crushers, I'm guessing not well!
-5mm Aluminium: I'm imagining some decent grade Aluminium alloy like Aero grade rather than the regular soft stuff, but not sure what sort of grades are decent or how much they would I cost
-6mm polycarbonate: this is obviously fairly cheap and easy to get hold of but again not sure how it would hold up against modern feathers
So can anyone offer any advice as to which one they would recommend or recommend anything else?
Thanks
Max
Thanks
Max
