Id recommend a DX6I aswell, just simply because if you ever become interested in the sport it will work out cheaper in the long run.
Also about Links, definitely use one. Much harder to get stuck inside a robot, and if it catches fire theres something nice about holding a little bit of wire to let you know its otherwise all safe :P - plus you will need to use links for the battery, so whilst your doing it you may aswell.
Also, check out the following link for ESCs and Threaded bar - will help with structure and reducing Australian postage
ranglebox.com
ranglebox.com
