new build atom
  • new build atom
    http://m.ebay.co.uk/itm/311311059992
    a thread for the odd question i may have.
    First has the name atom been taken?
    Also anyone tried these speedo's ive linked their rated at 16v max and have you ever overvolted them?
    i use them in night fury and scruffy but there are a few software versions on ebay so only some work properly
      Ok. i was gonna try some as a punt as they were cheap. I have a scorpian in another robot so will use that.
      I am replacing a motor on my k9 but i need some reverse screws for the drills can these be bought anywhere seperately.
        unfortunately the supplier i got mine from seems to have stop selling them each esc will happily run 2 drills on 4s and barely get warm after 3 min
          They kept coming loose on k9 so i threadlocked them. Think i overdone it with the threadlock and ruined the screw getting wheel off lol. My spare motor also seems to be missing the screw i think their m5 or m6 reverse thread.
            I had a set of those ESCs in Hardwired 1 and they had a brake function on, but happily took 2 drills each. They did also eat themselves after I put them in my beetle. They work fine in Scruffy/Night Fury from what I've seen but it's all really dependant on you getting the right ones which as far as I can tell is pure chance unfortunately...
              thanks for comments i think i will pass on them and just share my scorpian between this fw and k9, not a problem.
                Ok. I need to bend some 8mm thick strips of hdpe about 2" wide. I have a heat gun for paint stripping is that a good method? Or put it in the oven? Wondered what others have done and will it hold its shape once cooled.
                  I use a combination of L angle and a dedicated (Leister) plastic bending/welding heatgun.
                  Or for smaller bits up to 110mm wide, I take up my bender, and go with the heatgun again.
                    Ady if you're still after reverse thread screws I have a couple spare you can have, m5 ones.
                      Yes please sam!!
                        Quick question, when building a chassis out of hdpe, should I use threaded inserts on all joins? Including inner bulkheads and floor, or do some people use wood screws in places. To go into a full combat event
                          Neither ideally. The screws will wear down over time and the threaded inserts pull out. Barrel nuts and bolts are the way to go for HDPE.
                            Ok thanks for advice
                              For places where barrel nuts won't fit, you can use Tee nuts:
                              They are a type of nut insert that is pressed in from the far side of the HDPE and will not pull out. I have used them for years without problems.
