OK, here is the problem...I need to turn the drive from an S28-150 Magmotor through 90 degrees, I need to safely deal with both the max torque of around 13.5Nm and shaft speed of around 6000 rpm, my original idea was to use a set of induction hardened Mod. 2.5 straight cut (Gleason System) bevel gears but I have been warned that although it would work, that it could be very noisy. Would I be better off using a set of spiral cut bevel gears?
Or can anyone think of a better soloution.
Thanks
Geoff.
(Oh yes, one other thing, it needs to be as light as possible!!)
Thanks
Geoff.
