Now i know what i am about to say is probably very obvious to the most of you however for me i just cannot get my head around it.
Now i have a 4 Chanel 2.4 GHZ transmitter receiver set, a battery, 2x30A ESC's and 2 motors.
As far as i am concerned when i connect them all up and switch on the transmitter then receiver then i should have a RC robot.
What i want is for each of the two joysticks to operate one of the wheels so if i push both forward both wheels go forward likewise for backwards. If i push one forwards and one backwards it should turn on the spot. For the moment i do not care less about the sideways movement on the joysticks (one thing at a time).
My problem being that this does not happen, only one of the channels manages to move the wheel and when it does it is in a weird way were in that the joystick in its rest position is the motor running at mid speed with pushing up to slow/stop it and down to make it go full speed, the rest of the channels do not appear to do a thing.
So basically what i thought was a plug and play system has turned out to be a pain in the arse.
I assume that it is just me being an idiot and it is something super obvious however that's what i need to be told. Does anyone know what is going on and if so how i can sort it.
Thank you in advance for any help
