Lets for a moment forget certification and testing of pneumatic parts... would it technically make sense to build a square ram and buffer tank?
The reason behind the idea is to save space, and build a more compact machine. The buffer and ram can be bolted together as a single piece and will contribute to the overall rigidity of the robot.
The setup would run on Low pressure, say 10bar and material I'd use is extruded aluminium alloy - box or rectangular section for both ram and buffer.
I know box section is not ideal as a pressure vessel and there will be a tendency for the sides to bulge, but is it worth exploring the idea?
