Beefy motor for that ESC. I use that ESC for my truggy and it performs well but it is designed for 1/8th scale applications. The settings are adjustable for your needs, the programmer can minimize the forward/reverse delay to as close to 0 as you can get it. The motor itself should have no problem starting up with your reduction ratio.
Brushless drive ESC
 http://www.youtube.com/watch?v=3puKPFVUfdcOriginally posted by Mouldy View PostThat esc looks bang on Tim- shame there not sold pre-built.
 Should do nicely in fw-size robots. I'm planning on making a few.
 Unfortunately, the TZ85 in it's original form is not reversible - you need a car brushless ESC for that.Originally posted by daveimi View PostYeah I meant brushless ESC lol. Was wondering if TZ85's are already brushless and there are loads of them kicking about to begin with someone could give them a go?
 I am using 26:1 gearboxes and the pinion has a 1/8" bore. The set-up wouldn't have anywhere near the torque of your motors (775's, I guessing?).Originally posted by Mouldy View PostNick what ratio banebots did you run this year? Id be Kinda tempted if i could find a motor to mate onto my banebot 16:1's to run my 98mm wheels with similar performance to what im currently getting
 For your 16:1 gearboxes, I would use a pinion with a 5mm bore and either one of the NTM outrunners like Aaron @ BotBitz is testing, or a larger sensored inrunner like this:
 .jpg)
 http://www.hobbyking.com/hobbyking/s...or_1900KV.html
 If you want to wait a week or 3, I have a pair of those on the way for testing. You might want a bit different KV motor depending on your battery voltage and the speed you want - luckily there is quite a range to choose from. Will the 70mm can length be a problem for you?
 Getting a controller is not the issue, plenty of brushless controllers out there that are proven and reliable in combat robots (the Vedder controller is a big unknown). The big thing we need to do is develop software that will properly for robots and handle a variety of motors (If found some controllers don't like some pole designs in motors ie: H36 motors with a Trackstar controller). BotBitz is working towards hacking the TZ85A to work as a dual purposes controller in both it's current Brushed mode that we sell, but also a Brushless mode. The problem is we need a good amount of time to develop the code, test it with a large range of motors and conditions before we could even consider selling it. At the current moment, I find the Turnigy Trackstar 6S 150A V6 controllers to best off the shelf solution, they are fully programmable, zero delay, have a wide range of voltage (2-6S) which suits most robots and they also have sensor ports (Just need some good sensored outrunnersOriginally posted by cavecrusher View PostI'll just post this link again. Maybe someone is interested in some.
 http://vedder.se/2014/01/a-custom-bl...or-controller/ ). So while this controller is readily available, it kind of makes the job of hacking the 85A into a dual mode controller a reinvention of the wheel and therefore a slow progressing project. ). So while this controller is readily available, it kind of makes the job of hacking the 85A into a dual mode controller a reinvention of the wheel and therefore a slow progressing project.
 It's not a case of them not working, it's a case of the conditions they are applied to they don't always work correctly. We have plenty of videos (as posted previously) with robots driving around with outrunners with sensorless controllers, but if you put the robot in a standing start stall condition with full weight and traction, they don't work (Check my video where the weight is distributed level). If your robot gets pushed into a corner and the opponent pins you, the sensorless setups rarely startup and just sit their cogging (as seen in my video) until they can make the first commutation. This is where the sensored controllers really shine, even when stalled, they can begin commutation instantly. This is one reason why I'm trying the bigger NTM 42 series motors is to get better start up torque, not to get 500+ watts of power into the drive.Originally posted by Daniel View PostI still keep reading that sensorless outrunners won't work.
 Charles Guan (e0Designs/etotheiplusone) has done some epic builds with electric scooters and go karts using big outrunner brushless motors and ended up shifting to external to get reliable standing start performance in go karts, where 300lbs of weight taking off from a stand still with wheel spin is the game...
 EDIT: Forgot to comment against Nick's post.
 I already have a set of those motors for testing, however this is what I dont like about them:
 - Max of 4S means they are only suited to low voltage robots or you have to build split powered robots with two batteries.
 - Weight, they are 300+g each, which is nearly double the weight of a comparative outrunner.
 - Cooling, they are fully enclosed and rely purely on the small heat sink fins. You could add fans etc etc to them, but this is more weight, space, complexity and it's probably not as good as the cooling an outrunner provides to itself.
 - Size, they are pretty long motors, much longer then the outrunners and even Dewalts.Last edited by knightrous; 6 May 2014, 01:29.
 Hi Aaron,
 Those HK motors seemed the closest to what I wanted and a logical step up from the 540 sized motors in Mr Mangle. I don't think they will get too hot if geared right - the 540 motors got pretty hot on the bench test but not so much in the arena. The other plus with the sealed inrunners is that the dirt stays on the outside.
 Its obvious that both types of motors have their strong points; what we really need is for you and Steve to make an external sensor board for the NTM 35 or 42 series motors . That would tip the advantage solidly over to outrunners. . That would tip the advantage solidly over to outrunners.
 In Calliope we tried the NTM 28-36 750 KV. Once they go, they go like stink. Unfortunatly, getting them to go is a bitch.
 I'm redoing the drive with NTM42-35 750 KV in a desperate attempt to save the idea. Weight will be my enemy in this.
 An external sensor kit combined with a good sensored speedo could save the 28-36 setup. After all, those motors are in the same power-range as the common batterydrill setups.
 And I have a backup plan. But that ain't for next week.
 I've looked at pretty much copying the methods use by Charles for the external sensors, the problem is that you still have to tune the sensor to the motor, and this will change every time you pull the assembly apart. My currently idea is to try to develop a PCB that will fit inside the motor near the mount and stator to position the hall sensors between the stator teeth. This will remove the need to tune them in and will still provide enough cooling to avoid heat damage (A few industrial brushless motors I have seen have the hall sensors epoxied between the stator teeth)Last edited by knightrous; 6 May 2014, 06:19.
 http://alienpowersystem.com/product-...shless-motors/
 I forget if this has already been posted, but still. Sensored outrunners.
 They look interesting but a bit oversized for featherweights. The 42mm outrunner is about the best fit but its low KV and 22V limit makes it a bit low revving for my taste. The high voltage car ESCs also look interesting, they are the first I have seen that work up to 44 volts.
 I wonder if Alien Power would consider a custom sensored outrunner for the bot community? A 35mm motor with a KV of about 1000 and a 22V working voltage would work really well with a Banebots P60 26:1 gearbox.
