I'm designing a walker... the 2 times weight allowance is very persuading. But anyway I'd like some help with calculating torque required to push my little friend forward.
Looking at the top end of featherweight I have just over a hefty 27kg (2x times weight allowance) weight to carry.
I know the formula to calculate torque to lift the robot and sustain it, but not the torque required to propel it forward. I'm actually going to be using a pneumatic system to lift it, and servos to propel the body forward once it's in the air.
The servos will drive horizontal bevel gears with a leg bolted/welded to each one providing the movement forward and backwards for each leg.
This is my torque formula to lift the robot:
Torque = (weight/legs on ground)*length of legs*acceleration
N = 28kg/3 = 9.34N
Nm = Force * radius(leg length)
Nm = 9.34N * 0.15m
Nm = 1.4Nm
Account for acceleration of gravity
Nm = 1.4Nm * 9.81 m/s/s
Torque Required = 13.734Nm
Is this also the minimum required torque for my propelling servos? It looks to me like I would not require as powerful servos because the downwards force of the robot is already accounted for by the lifting actuators.
Can someone shed some light please?
Thanks,
Dan
N = 28kg/3 = 9.34N
Nm = 9.34N * 0.15m
Nm = 1.4Nm
Thanks,
Dan
