Although I am am a necomer to this forum, I am close to completing a Featherweight after 18 months of construction.
I have recently purchased a 40MHz Car & Boat aerial and GWS PG-03 Gyro from Technobots. What is your preferred method for connecting the aerial to the RC receiver; should the entire length of the RC aerial wire be connected, or can the wire be shortened? Also, should the wire be directly connected to the screw terminal, or capacitively coupled via say a 10nf cap and is it sensible to screen the aerial wire and ground plane the aerial? I appreciate that this is not an exact science and Im not looking for theoretical perfection, but any advice you can give based on your or others practical experience would be most appreciated.
